Current harmonics measurement is too big, is it common?
Recently I measured current harmonics component in mine industry. But the results are not as I expected. The max current supposed to be 380 A, but when I measured my Power Quality Analyzer displays 1026 A which is at the fundamental frequency, while the total current harmonic(all frequency) is about 1200 A rms. Notice that, I measured it in one phase.
RE: Current harmonics measurement is too big, is it common?
The voltage THD shall be less than 10 percent in industrial plants with an occasional 15% allowed for short periods. The voltage THD is what one usually cares about. What is it in your case?
Gunnar Englund
www.gke.org
It's only the THDV that has any effect on your infrastructure.
Gunnar Englund
www.gke.org
