Relief Valve Vent Stack - Testing Pressure?
Hey guys,
I have a relief valve acting as a form of over pressure protection before a meter station. I am currenty fabricating the discharge piping. Does the outlet piping need to be pressure tested? To what pressure? It it ANSI 600 inlet but ANSI 150 outlet. It is venting to atmosphere, has a set point of 1480psig, and needs to dishcarge 60MMSFCD.
thanks for any replys
RE: Relief Valve Vent Stack - Testing Pressure?
Independent events are seldomly independent.
I sincerely hope that any confusion over what was posted and what I thought was implied will not cause anybody any undue grief.
An open ended line and even a pressure vessel require no testing. What's next hydro testing your 100 foot tall flare stack
