ASME Section IX: QW-151.3 Question
A 1.5 inch plate was tensile tested using turned specimens. Two .500" diameter specimens were pulled for each required set. Does one more specimen have to be pulled representing the full thickness of the test coupon?
RE: ASME Section IX: QW-151.3 Question
I've found that it usually helps me if I sketch these things out and include the layout with the PO to the testing facility. I make the assumption that everyone around me is also spatially challenged thus needing it on paper.
