Rust Particle Density as a Function of Diameter
Hi all,
I would like to determine an approximate relationship between a rust particle's diameter and it's density.
Wikipedia reports the density of Fe2O3 as 5.242 g/cm3 (solid). I would consider this the upper limit on rust density, which should decrease with increasing diameter. However, I have no other source to base a range of density values on as a function of particle diameter.
If anyone is aware of a density value for rust, please inform me.
Thanks!
Thanks!
RE: Rust Particle Density as a Function of Diameter
Aaron Tanzer
www.lehightesting.com
