Reuse Library - 2D Section Library
Greetings,
I am learning the 2D Reuse Library and I'm having some troubles with adding 2D sections. Is it possible to add the 2D section when in sketch-environment, or do I have to add it at part level?
Anything you all can send me would be greatly appreciated!
Best Regards,
A
Best Regards,
A
RE: Reuse Library - 2D Section Library
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you for your quick response.
Would it be possible to create 2D sections out of curves instead of sketches and would those be able to be dropped into a sketch?
Best regards,
A
If it's the '2D Section' library, just add the section to your drawing and edit it. You'll find that it's simply a sketch which you can add to it anything that you want.
However, if you've already created your own sketch you still have a couple of options available to you.
First, there's nothing stopping you from adding one of the '2D Sections' to your model and as long as it's before your own sketch in the Part Navigator feature list and on the same or a parallel plane to your sketch, you can simply project the curves into your sketch. Of course, the sketch would have no control over the shape of those curves, but at least they could be part of your sketch profile.
Or you could simply open the '2D Section' sketch. 'Copy' the curves and constraints of interest and then 'Paste' them into your sketch.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
But i am experiencing same problem at here also (i can't able to control the size of 2d reusable sketch. please see attached image for details)
please suggest a way
