Breakout section depth in NX8.0 Drafting
How do I specify the depth of a breakout section in NX8.0 Drafting. There is an option to "cut thru model"?.... I need the cut to go to a specific depth, I can't think of a situation where I would not need to specify the depth of a cut...
RE: Breakout section depth in NX8.0 Drafting
...is where you select that point in the model where the 'Section' will start (or stop depending on how you think about it). Generally you have to select that point from another view on the drawing.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks it's working well now.
