Submitting job, nothing happens
Hi.
Im using Abaqus CAE 6.12 to analyse a bolted steelconnection. The model worked fine when running it a couple of times and I tried to refine the mesh to see the difference in results before running it the third time. Suddenly, when submitting the job, nothing happens and the job won't stop when killing it. I've read through the forum and tried deleting the .log- and .lck-files from temp in addition to restart det program. How can I fix this?
RE: Submitting job, nothing happens
If the job is running, kill it through the task manager.
If it still says (running) you can copy the job and just delete the old one.
Best regards,
S
When I tried running it from command i got: "standard" licence request queued for the Licence server for 1s, 31s, 61s and so on. then after a while it just worked.
Probably some issues with the licence access then?
