Is it possible to test SNAP without licence ?
When trying to learn SNAP by my self with this simple Program (found in the SNAP Reference Manual) I have the following message for each line with 'Info Window'
'InfoWindow' is not declared. It may be inaccessible to its protection value.
What's wrong ? I thought this simple program worked
____________________________________________________________________
Imports Snap, Snap.Create
Partial Public Class MyProgram
Public Shared Sub Main()
Dim myString1 As String = "The sky is blue!"
Dim myString2 As String = "The air is fresh!"
Dim myStringArray As String() = {"Sunny", "Windy", "Rainy"}
InfoWindow.Write(myString1)
InfoWindow.WriteLine("")
InfoWindow.WriteLine(myString2)
InfoWindow.WriteLine(myStringArray, 10)
End Sub
End Class
_____________________________________________________________________
TIA
End Sub
End Class
TIA
Didier Psaltopoulos
http://www.psi-cad.com
RE: Is it possible to test SNAP without licence ?
Starting with NX 8.5 we are now including, free of charge, 'MiniSNAP' (a subset of SNAP) which will allow you to test the basic capabilities of a SNAP program by running it from the normal 'Journal Editor'. There is enough functionality available so that you can run all of the sample programs outlined in the 'Getting Started with SNAP' guide which can be found in the NX Help files for programming tools.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Didier Psaltopoulos
Please remember that the purpose of 'MiniSNAP' was to provide a way for users to 'test drive' the software by being able to work out the sample programs provided in the SNAP getting started guide, but not a whole lot more than that.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
CODE
www.nxjournaling.com
Thanks for your answers. Now I understand how to test MiniSnap.
Didier Psaltopoulos
