Load mapping from API
Hello everybody,
I am working on a API script which is applying a laod from a scource to target model. I have managed to do that, but with a help of a dialog box to pick element and faces.
My question is:
Does anybody have an idea how to pick up element faces from all the elements located on different surfaces without a dialog box.
I am searching to speed up the process, because of many load cases.
I thought about getting ID's ftom "Get array" but for faces I run out of ideas.
Thank for help.
Jendrooh
My question is:
Thank for help.
Jendrooh
RE: Load mapping from API
Please drop the API file here to help us better understand your problem.
Thanx.
I have solved the problem. The array of face IDs and element IDs was not defined properly.
Thank you for replying, I will keep in mind to attach the code next time.
Jendrooh
