Position Representation
I am using Inventor 2013 professional. I want to show a rubber bellow stretched in a non Master Position Representation. Should I use rubber bellow as iPart and then place it in the Assembly or else?
RE: Position Representation
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si...
Adaptive command is disable for rubber bellow (which is a part) in the assembly. Extrusion of the rubber bellow is adaptive in rubber bellow.ipt
