Rotating in the Z axis
I'm working on an Iso that I want to rotate an object on it's z axis, is there any way that I can do it?
RE: Rotating in the Z axis
Dude,
have you tried to just rotate in top view?
Use the power selector and click the rotate icon AND ...
Then snap to the Center of your object...
That should do the trick ...
Otherwise? I believe you have to draw construction lines to rotate at the center point or base point you're after.
Hope that helps ....
Later!
Rich@LG (Architect)
