API 624 Fugitive emission testing
If any body knows what is max fugitive emission (PPM level ) as per API 624
AL
RE: API 624 Fugitive emission testing
Have you seen API 624 copy ? I have read the draft copy only . Where acceptance criteria are subject to agreement between the end user or when superseded by local ordinance .
What is the time element for the 100ppm, hsbcn?
API 624 is still in draft. I suspect that after the the API meeting this April it will have final approval. The current draft does have the acceptance criteria as 100ppm.
