Help ID Crosspoint screw-in fittings on pump body
Hi guys:
I'm trying to find the correct tool to remove the crosspoint/philips-like covers on the radial pump shown in the attached picture.
It is powered by the engine of a rally car and used for operating the power steering and the hydraulic shifitng of the manual transmission. Size is about 3 inches diameter and about 10 inches long, mounted on the engine block with multi-v belt connection.
The pump was made by Toyota Team Europe in the mid/late 1990s and I'm trying to get it operating, but it now has no pistons (other internals/eccentrics/one-way valves are ok, I think).
Any idea as to the tool used to remove (unscrew) the caps/covers over each piston bore? Covers are about 3/4 inch dia, but probably metric sizing. The pump body was made in-house, but the caps appear to be commercial - die cast, etc.
Thanks for any help you can provide. Bruce
RE: Help ID Crosspoint screw-in fittings on pump body
Creating a custom tool out of two crossed pieces of flat plate steel seems like it shouldn't be too hard. I've seen these caps before (or ones close) and in a pinch, a LARGE flat blade screw driver might work. How often do you anticipate removing/installing these caps?
SceneryDriver
I think I've seen vaguely similar heads on the ends of heavy duty drag links and such.
Snap-On used to sell sockets (basically big screwdriver tips) for wrenching stuff like that, but I couldn't find them in the online catalog, and you didn't give us measurements of the cross recess dimensions so I gave up looking.
Mike Halloran
Pembroke Pines, FL, USA
looks like a very simple exercise for any mechanic / fitter / hands on engineering type person to make a removal tool and to apply it.
Thanks for the ideas on this. The latest update is I found out from the rally team that the internal "guts" of the pump are from ZF (the German automotive/commercial vehicle supplier) and used on large trucks and off-road vehicles. The original cast-iron body was discarded by the team and a new (quite intricate) body was machined out of aluminum. See the picture of the exploded pump attached.
A screwdriver blade was too thin and was buggering the slots on the screw-in covers so I bought a 5/8 in cold chisel and ground the tip to fit the slot. The chisel has a hex shank so I used a box wrench for leverage to remove the screw caps.
Interesting that current ZF radial pumps now use only a single slot in the covers not a cross.
Thanks again for the suggestions! Bruce
