Not enough work to do in consulting
I've read a couple threads on the site about what to do when you don't have enough work. I'm in a slightly different situation from many of the posters in those threads, in that I work for a consulting company and need to fill out a time sheet. The past couple weeks I've had a lot of time that has just gone on overhead and have had to explain to my boss what I've been doing.
The thing is, I've asked for billable work from coworkers and even my direct boss but things have been kind of lean. I can fill my time doing lessons learned type documentation, coming up with documented procedures etc., but none of that can be billed.
I've only been at this job a couple months, so I worry that asking for work all the time will threaten my job. If I don't ask for work, however, and spend my time doing things that are useful, but not billable, I cost the company money. It's a lose lose. The thing is, the billable work I have received I think I've performed well on. It's just that people need to give me a chance to help them.
Any suggestions on how to make myself relevant within the department so that more work is directed my way, all while not seeming 'whiny' about it or being a nuisance?
RE: Not enough work to do in consulting
If so, complete it.
If not, the discussion with your boss should have been simple, either:
"I have completed all the billable work I have available. What else do you have for me?"
or the slightly more nuanced
"I have completed all current billable work, until the Smith/Jones/Barry accounts respond to my questions/have our progress meeting Tuesday. I expect I have about 20 work hours until then. What other billable work do you have for me in the meantime?"
You need to be proactive and communicate this until you are assigned to do something. Of course your job may be on the line, but sitting around wasting time is not going to help your cause.
B.E.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
I have no more idea than anyone else on here as to what is around the corner at where you work, but if they have only just taken you on and are still employing you that says to me that they are happy with you and expect things to improve in the near future and are prepared to take a short term hit in order to keep you.
My advice would be to go to them and say something along the lines of if there is no billable work in the short term would you like me to sort out (whatever in your opinion needs sorting out) or would you sooner I spent the time studying or reading up on standards etc or would something else be of more help?
I short offer a couple of solutions or give them the chance to tell you what to do with the “spare” time.
At any rate, one of the oddities of consulting is that being 100% billable drives down the actual overhead rate. So it's actually good to charge overhead once in a while to help the company justify the overhead rate that it claims on government contracts.
the fact the you need to "ask" for work, clearly indicates to me that your supervisor may not be on top of things. A good supervisor would be communicating with you what is required on a frequent basis and would certainly encourage you to ask questions. The fact that this is apparently not happening should be a big red warning flag.
just because your are still employed does not mean your boss (which may be somebody higher up than your direct supervisor) is happy with your performance. nor does it indicate that business is improving or that the company intends to keep you on. You could just as easily be called into the office this Friday and given your walking papers.
Second time: After a couple months of struggling to keep busy, I was let go. Months after, company went dark.
Third time: Struggling to stay busy while management openly questioned whether my position was needed. Cut loose. Learned later that new product development was stopped in all divisions and all design-related personnel were let go.
Same story some years ago, was hired on , busy for first 3 months, then company did not get an expected contract. Work dried up in the office, I re organized file folders, and drawing racks spent time learning ansi codes, then the call to the bosses office, given separation package.
Three months later, company is bought out and facility closed.
Heartland ce
You wonder why I say polish your resume, you may survive if they have an upcoming big project and are prepared to carry you until then.
B.E.
Is there anyone out there who has never worked for a company that has lost a project or had one put on hold that has meant things are slow for a while that has recovered and things have worked out fine?
What a good job company owners don’t feel this way, if every time there was a slight downturn they thought oh well that is it I might as well walk away there would be no jobs for anyone.
I work for a company that went through hard times (more than a few months, a few years instead) but did their best to keep people and avoided a layoff for most of those years. Then they were forced to layoff about 15% of the work force, but managed to avoid cutting any deeper. Then business picked up and the people they kept were very glad to be there, including me.
My point is there are two examples that illustrate the extremes, and no one can predict where you current company is on the scale between these extremes. What you are seeing in this forum is the multitude of varied experiences. A person who when through the first extreme would most likely say run as fast as you can somewhere else, but a person who when through the second extreme might advise hanging on at all costs.
Which would give you the better advice? Who knows, but remember to allow people from who you ask opinions to share their opinions. The most important thing to remember is occasionally the most necessary information you may receive could be couched in words, terms and attitude that you don't like. My personal recommendation? Learn from the information and ignore the tone. There are persons on this forum (I have monitored for years) who would probably be delighted to punch out my lights if we ever had a five minute face to face conversation, but from who I have also learned valuable lessons by reading to understand, not to refute.
Because in my forty years I have seen plenty of the extremes and the middle, I recognize the precarious nature of your position right now, and I wish you success in choosing what path you will follow.
debodine
Keep asking your supervisor for work. If there isn't any, ask what you could do to be productive. Are there typical details that need updating? Maybe there's standard specifications where the manufacturers have changed model numbers and you can update them. Sometimes there's projects that have room in their budgets for a few "miscellaneous" hours charged.
You're right to be a little worried. But when you get down to it, it's not your job to keep yourself busy.
I would suggest paying attention to what's going on. If no one is complaining that you are sitting around not billing hours, you probably are okay.
B+W Engineering and Design
Los Angeles Civil Engineer and Structural Engineer
http://bwengr.com | http://bwstructuralengineer.com | http://bwcivilengineer.com
