Stall Speed vs Altitude
Can anyone help me understand these graphs?
I thought the Stall/CLmax would occur at a roughly constant KCAS. What could explain the kinks in the curves? The graphs are for a Gulfstream IV (blue) and a G450 (green). The have a virtually identical wing, except for fewer vortex generators on the G450.
Thanks!
I wasn't sure how to attach two files, so hopefully these links work:
http://files.engineering.com/getfile.aspx?folder=9...
http://files.engineering.com/getfile.aspx?folder=0...
Thanks!
RE: Stall Speed vs Altitude
The pilot flies always KCAS (calibrated air speed, knots) information that gives the Airspeed indicator. From a certain pressure altitude, KCAS is practically constant. Obviously the TAS (true air speed) increases with the pressure altitude.
The shape of KCAS curves may result from low speed buffet boundaries at high pressure altitude.
CAS is indeed what the pilot sees on the instrument, is close to EAS, whereas TAS has the density ratio factoring.
Quando Omni Flunkus Moritati
If the middle segment was a constant Mach number, I believe the CAS would decrease with altitude.
Since we are dealing with low speeds, I wouldn't think compressibility needs to be considered.
Any other ideas?
http://en.wikipedia.org/wiki/Coffin_corner_(aviati...)
B.E.
I will try below.
B.E.
Please explain.
Thx.
