run time error
run time error
I am over loading this scripted in the underlined areas, anyone got any ideas on how to do this export in a better fashion.
Sub ExportArchive2()
' ExportArchive Macro
' Save ARC_EXPORT as MSDOS text file.
' This is the Microstran Archive File.
' Your directory is
myDirectory = "C:/"
' Go to the sheet with the Microstran File on
Sheets("ARC_FILE (2)").Select
' Store the information by first geting a file name
ChDir myDirectory
fileSaveName = Application.GetSaveAsFilename( _
fileFilter:="Archive Files (*.arc), *.arc")
' Store if a valid name and file is available
If fileSaveName <> False Then
MsgBox "Saving as " & fileSaveName
fileNumber = FreeFile
Open fileSaveName For Output As #fileNumber
' Cycle through the range storing each line as text
For thisRow = 1 To 48000
' Cycle through the range storing each cell on a line
For thisCol = 2 To 11
Print #1, ActiveSheet.Cells(thisRow, thisCol).Text;
Print #1, " ";
Next thisCol
' Finish the line
Print #1,
Next thisRow
Close #fileNumber
' Store the input data acknowledging where placed
Sheets("pre purlin").Select
ActiveSheet.Cells(6, 2).Value = fileSaveName
End If
End Sub
' Your directory is
myDirectory = "C:/"
ChDir myDirectory
Print #1, " ";
Next thisCol
' Finish the line
Print #1,
Next thisRow
Close #fileNumber
End If
End Sub
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
RE: run time error
RE: run time error
TTFN
RE: run time error
(2B)+(2B)' ?
RE: run time error
If so, I suggest writing each line to a string array, dimensioned as:
Dim TextArray(1 to NumRows, 1 to 1)
Then if you have a range named "OutputRange" on the spreadsheet you can write the array to it with:
CODE -->
With Range("OutputRange") .ClearContents .Resize(NumRows, 1).Name = "OutputRange" End With Range("OutputRange").Value2 = TextArrayDoug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
RE: run time error
I will see if I print the textarray to a txt file.
RE: run time error
RE: run time error
Or maybe they have a maximum size of around 20,000 rows, I don't know.
Doug Jenkins
RE: run time error
The vba is in excel and could be exported to a txt file or any test type file. I am really struggling to figure out why excel breaks down at 20000 rows.
