Rigidity Calculation Requirements for ASME Sec VIII Div 1 Nozzles.
Is there a specific requirement in ASME Section VIII Div 1 for the regidity calculations to be performed on (Example) an 18" manway in a pressure vessel?
If so, where is this stated?
Thank you,
Woodsman
Thank you,
Woodsman
RE: Rigidity Calculation Requirements for ASME Sec VIII Div 1 Nozzles.
Large, thin walled tanks with massive agitators have failed in the past, as they rock thier way to cracks and ultimate failure.
Info here:
http://www.eng-tips.com/viewthread.cfm?qid=237691
