Water Treatment
Water Treatment
I am looking for a program that can model small water treatment systems for camps and resorts. Basically our set-up is always an intake from a lake source to a low lift pump station through treatment (filters, uv, chlorination) and then to a holding tank or standpipe.
How can I model the pressure losses through the filtration system. I suspect you can get rather large losses through a 1 micron filter when flow rate is close to the maximum allowable for the filter.
Is there any way to calculate the losses through a series of filters?
Joe
Joe
RE: Water Treatment
Independent events are seldomly independent.
RE: Water Treatment
How do I find pressure losses through a series of cartridge filters?
DO you have a sample spreadsheet on hand?
RE: Water Treatment
RE: Water Treatment
Is the assumed pressure drop for a 25 micron filter the same as a 1 micron filter?
Thanks for your help.
RE: Water Treatment
