DCP Australia (9kg, 30 degrees) for bearing capacity
A task was given to use DCP Australia (9kg, 30 degrees, blows for every 100mm ) to test for bearing capacity. The test is carried out for crane pad purposes.
The question is how to workout the bearing capacity based on the dcp results? Thank you
RE: DCP Australia (9kg, 30 degrees) for bearing capacity
Sounds a bit like the Mackintosh Probe - but the Machintosh uses a 5 kg hammer. In any event, I've attached a couple of web sites for you to look at and see how they develop "supposedly" safe bearing pressures.
http://www.foundtest.com.my/services/mpt.html
http://www.gnpgeo.com.my/download/publication/Lect...
http://nrmt.files.wordpress.com/2010/02/513-week8....
Hope this drives you in the right direction.
