re: HDPE properties and blowmoulding thickness prediction
Hello Plastic Gurus,
I have two queries:
1) Does anyone have good low temperature data on HDPE? I am interested at about -30 , -40 degree C. How does the mechanical properties change w.r.t room temperature.
2) I need to analyze some blow-moulded HDPE designs for impact strength. I can use a nominal thickness in the analyses, but the actual part ends up having different thickness distributions which gives very different results in the actual tests. Is there a predictive tool which can determine the thickness distribution by simulation? A good prediction might avoid costly tool-changes later on.
Ace
RE: re: HDPE properties and blowmoulding thickness prediction
I think the people at Norner (www.norner.no) can model this for you and also provide the temperature dependency of properties.
Dr. Chris DeArmitt - FRSC
www.linkedin.com/in/chrisdearmitt/
