IBC 2009-Wood shear wall aspect ratio
IBC 06 had this table @ 2305.3.4. But I couldn't find an aspect ratio table in 09. Was it moved or should we be using NDS?
RE: IBC 2009-Wood shear wall aspect ratio
Per the 2009 IBC Section 2305.1 "...designed and constructed in accordance with AF&PA SDPWS..." Look in the AF&PA SDPWS for the ratio information. It is a free view only download from http://www.awc.org/Standards/SDPWS.html.
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
It is in the SDPWS. Most of this information is moving out of the IBC/IRC and into the reference material.
