shut off valves
shut off valves
shut off valves
do you know what is shut off valves and where is it applied?what types of these valves are?
Thanks for your kind advise.
RE: shut off valves
Shut-off valve is a valve that can be closed quickly if an emergency situation occurs in you facility. The valve has an actuator that operates on air, UPS, hydraulic fluid, etc.
RE: shut off valves
i think thats an emergency-shut of valve (ESV).
As far as i know a shut of valve is a common designation for any valve that is either open or closed be it manually or mechanically actuated. It should of course "shut something of" eg. a pipe section a piece of equipment or the like. A ESV is also a shut of valve but in an emergency shut down loop.
Best Regards
Morten
RE: shut off valves
I don't know the designation used in other countries, but in the oil and gas industries that I have worked for, SDV designation is used for Shut Down Valve. This is also in accordance with API-14C, Table 2.1
For Shut off valve, the first thing that came to mind is tight shut-off valve. These are basically manual valves in which 2 valves can be installed in a line to provide tight shut-off when the line is not in service.
I stand to be corrected.
