finding/deleting links
Here is my scenario
We have what we call our "MASTER ASSEMBLY" which we use when we start a new job. It is made up of multiple sub assemblies and catparts. When we start a new job, we take this assembly and store it under it's new job number e.g. 1234
We do not change any of the files names, we add/build/instantiate components accordingly to that specific job. Once complete, we do a File/Send to/ and release all data to manufacturing on another network drive.
Problem now is sometimes when doing File/Send to, it will send all files existing in folder 1234 then also grab files with the same name from another previous job 4567.
When i do File/Save management on "MASTER ASSEBMLY" in job folder 1234, all file associated are saved to the 1234 path. Only when doing the send to is when i see the other linked files. Our assemblies our very large so it is difficult to find which files are the issue using the desk command. Is there another way to determine why there is a link to anohter job, and how to manage/remove these links. I dont fully understand how the"linked document localization" works
RE: finding/deleting links
I believe you have users which are using Save As but without taking care of UUID.
That's why is good a PDM system, no matter how "light" is it....you can avoid a lot of problems and tracking/doing versions of products are really easy to be done.
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
You are correct, users are doing a Save/As and not taking care of UUID.
Another way it would be create a macro (again macro) in order to check if everything is in same folder or in others.
Fernando
Run the batch utility CATDUA. Check/Clean the template or job to remove old links.
Derek
Win XP64
R20SP7/21SP5, 3DVIA Composer 2013, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
Then when you do the second Send To operation to export the files, sort the list according to directory and don't transfer anything from the old Master directory.
Another idea that might be useful is I've found that the Send To command also respects Linked Document Localization settings. For example, you could set the Localization settings to only "Folder of the Pointing Document" when you do the Send To for exporting.
Hope that helps.
-Mark
