Create new program object - journal
Here is a journal which creates cam program object. New program name is created from previously selected program name number +1 ( name[Integer] +1). Is it possible for journal to automatically find last created program (without preselect) get its name and create new one.
PS. How to check if Cam Object is program object and how to check if program already exists.
CODE
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.CAM
Imports NXOpen.UF
Imports NXOpen.Utilities
Module nextprog
Dim theSession As Session
Dim theUfSession As UFSession
Sub Main()
theSession = Session.GetSession()
theUfSession = UFSession.GetUFSession()
Dim WorkPart As Part = theSession.Parts.Work
Dim setupTag As Tag
Dim selectedTags() As NXOpen.Tag
Dim selectedCount As Integer
' If there is a work part only then we can go further
If WorkPart IsNot Nothing Then
theUfSession.Cam.InitSession()
theUfSession.Setup.AskSetup(setupTag)
' If there is a setup only then we go further
If setupTag <> 0 Then
' Get the selected nodes from the Operation Navigator
theUfSession.UiOnt.AskSelectedNodes(selectedCount, selectedTags)
If selectedCount = 0 Then
MsgBox("Nothing selected", MsgBoxStyle.Exclamation)
Exit Sub
End If
Dim i As Integer
For i = 0 To selectedCount - 1
Dim camObject As NXObject = NXObjectManager.Get(selectedTags(i))
Dim CurrentName As String = camObject.Name()
Dim value As String = CurrentName
Dim int As Integer
int = CInt(value)
Dim Newname As Integer
Newname = int+1
Dim nCGroup1 As CAM.NCGroup = CType(workPart.CAMSetup.CAMGroupCollection.FindObject("NC_PROGRAM"), CAM.NCGroup)
Dim nCGroup2 As CAM.NCGroup
nCGroup2 = workPart.CAMSetup.CAMGroupCollection.CreateProgram(nCGroup1, "mill_contour", "PROGRAM", CAM.NCGroupCollection.UseDefaultName.False, Newname)
Dim programOrderGroupBuilder1 As CAM.ProgramOrderGroupBuilder
programOrderGroupBuilder1 = workPart.CAMSetup.CAMGroupCollection.CreateProgramOrderGroupBuilder(nCGroup2)
Dim nXObject1 As NXObject
nXObject1 = programOrderGroupBuilder1.Commit()
programOrderGroupBuilder1.Destroy()
Next i
End If
End If
End Sub
End Module
