DCP Australia (9kg, 30 degrees) for bearing capacity
A task was given to use DCP Australia (9kg, 30 degrees, blows for every 100mm ) to test for bearing capacity. The test is carried out for crane pad purposes.
The question is how to workout the bearing capacity based on the dcp results? Thank you.
RE: DCP Australia (9kg, 30 degrees) for bearing capacity
Don't post in more than one forum . . . it is discouraged (big time).
