surface generation from multiple cross sectional data
If I import a series of cross-sectional data, can I generate surface?
cross sections are similar, but not same.
and after the surface generation, can I export the surface information?
If it is possible would you let me know how to?
I am so beginner.
Thank you,
RE: surface generation from multiple cross sectional data
Thanks Greg,
So, you mean, HM itself doesn't have surface generation function,,,
To make surface from the cross-sections, I need to do outside of HM, then import to HM,,
Is it correct?
Thanks again!
