Specifying Feed Limits
I need to specify parameter limits to a water treatment plant supplier, but I only have ten data points. How is this usually approached? Do I double the mean of my data set, or do I specify that the design should be to accommodate the mean plus three standard deviations from the mean?
RE: Specifying Feed Limits
Particular pieces of equipment have typical performance standards as well.
What parameters are you considering and what is the purpose of the equipment.
Good luck,
Latexman
Conductivity is rarely used in wastewater treatment unless one is doing some type of desalination process.
