valve ratings in bs en 12266
hi
Does anybody knows what are the valves rates (A-G) in table A.5 in bs en 12266 refer to?
I am trying to create an acceptance criteria for resilient seated ball valves leakage rates in natural gas PRMS's and dont know which rate to choose.
thanks,
david
thanks,
david
RE: valve ratings in bs en 12266
ballsellman, when you say that resilient seated ball valves leakage should be zero, you put the valves under RATE A.
where is it written? which valves should be under RATE B? C?, D?....
David.
API 6D/ISO 14313 set criteria for acceptable leak rate according to ISO 5208 in the testing chapter.
Leakage for soft seated valves shall according to API 6D not exceed ISO 5208 Rate A
ISO 5208 is harmonized with ISO EN12266
