Nitriding and NACE Code MR0175-3-2009
Looking at NACE MR0175 Second Edition 2009-10-15, section A.1.5.1, Requirements for overlays, surface treatments, plating, coatings, linings, ect...
It it says, "Nitriding with a maximum case depth of 0.15 mm (0.006 in) is an acceptable surface treatment."
I would think the metal would have more protection against substances such as H2S. I have seen typos in standards before, and curious if they meant minimum rather than maximum.
What would is the effect if the nitriding was deeper to 0.025 in or 0.030 in?
What could be the issues if the nitriding exceeded the 0.006 in depth for protection in product containing some H2S?
RE: Nitriding and NACE Code MR0175-3-2009
surface hardness
nitriding hardness depth, NHD
compound layer thickness, CLT
For specification of nitriding hardness depth, the symbol NHD is used. The limiting hardness is usually 50 HV0,5 added to the actual core hardness, with the nitriding hardness depth given as a nominal dimension in millimetres. For example, the drawing may have the following specification:
plasma nitrided
> 950 HV10
NHD = 0,3 + 0,1
This means that the surface hardness must be > 950 HV when using a 10 kgf load. The case depth must be 0,3 to 0,4 mm deep, with the value of NHD determined as the depth at which the hardness is 50 HV higher than the core hardness, using an indentation load of 0,5 kgf. The terms Effective Case Hardening and Total Case Hardening are not used. Also, note that a comma is used as the decimal separator instead of a point/period.
http://isotc.iso.org/livelink/livelink?func=ll&...
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
