EPANET 2 - problem with a constant flow without using flow control valve
i have a problem to limit the flow in a pipe in Epanet.
the transmission line is based on gravity with a reservoir at the top and a tank downstream. i want to have a constant flow through the pipe without using a flow control valve. is that possible?
I tried to use a node with a constant demand (=my deliberate flow) after the tank, but the only thing happening is that the tank is filling and emptying seperatly..
I hope you can help me!
RE: EPANET 2 - problem with a constant flow without using flow control valve
Independent events are seldomly independent.
