How could I access a part of subass
How could I access a part of subassembly from assembly document via VB?
RE: How could I access a part of subass
Dim objApp As Object
Dim objParts As SolidEdgeAssembly.Occurrences
Dim objDoc As SolidEdgeAssembly.AssemblyDocument
Dim objPart As SolidEdgeAssembly.Occurrence
' Connect to a running instance of Solid Edge.
Set objApp = GetObject(, "SolidEdge.Application")
If GetActive = True Then
Set objDoc = objApp.ActiveDocument
Else
Set objDoc = ActiveDoc
End If
Set objParts = objDoc.Occurrences
For Each objPart In objParts
Dim FileName As String
FileName = objPart.OccurrenceFileName
Next
Dim objDocSubAss As SolidEdgeAssembly.AssemblyDocument
Dim objPartsSubAss As SolidEdgeAssembly.Occurrences
Dim objPartSubAss As SolidEdgeAssembly.Occurrence
Else
End If
Set objDocSubAss = objPart.OccurrenceDocument
Set objPartsSubAss = objPartSubAss.Occurrences
For Each objPartSubAss In objPartsSubAss
Next
Next
