dwg file size
dwg file size
Just wondering what a reasonable size would be for a dwg file.
Ive got one at the moment about 20Mb, not causing me a problem but Im wondering is it too big for its brichess ?
RE: dwg file size
I receive drawings from architects all the time that are 15- to 30 MB, and they have hundreds of layers with unintelligible names. I have to lay out electrical, controls, and some parts of air distribution. My computers are very fast and have very fast GPUs, so it's not noticably different from a small file.
I got a HUGE one once, 200 MB, and I had to work with it on a laptop for a few days while out of town. I wasn't drawing, I was doing a takeoff. I found that for most purposes, DraftSight was sufficient and probably 10X faster than AutoCAD in loading, rendering, and panning around. Another fast way for read-only work is to plot the drawing to a pdf, then load it with Foxit reader. That's even faster than DraftSight.
Most of mine that I do from scratch are much smaller, in the 20- to 100 kB range.
7-zip crunches a 20 MB file down to about 5 MB is storage is getting out of hand.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
RE: dwg file size
RE: dwg file size
Did you try to purge and audit the drawing a few times?
B+W Engineering and Design
Los Angeles Civil Engineer and Structural Engineer
http://bwengr.com | http://bwstructuralengineer.com | http://bwcivilengineer.com
RE: dwg file size
That takes some time, but I do it if I have to draw. If I'm just reviewing or taking off material quantities, I use the DraftSight or Foxit pdf reader methods.
Best to you,
Goober Dave
