Shaft Vibration
Shaft Vibration
My understanding of modes of vibration / failure of drive shafts is as follows
1) Torsional
2) Lateral (with/ without rotation)
3) Whirl (of shaft, not bearings)
However there seems to be a lot of confusion about what is whirl and what is lateral vibrations, some sources say they are the same thing (or rather whirl is caused by the onset of lateral resonance).
Other sources suggest that whirl is an issue in its own right, and the only governing factor is a critical number based on a simple equation.
Some sources ignore whirl it all together.
I have a supplier providing a fairly long vertical drive shaft at fairly high rpm, and need to brush up on my shaft design headline issues!
Thanks in advance.
1) Torsional
Thanks in advance.
RE: Shaft Vibration
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
RE: Shaft Vibration
induced by transverse motion.
For example consider a single degree of system with mass at the center of a shaft with end bearings.
1)If the spring constant is k, then the natural lateral resonant frequency would be wn=Sqrt(k/M). If the lateral driving frequency is w, then the undamped motion amplification would be (w/wn)^2/{1-(w/wn)^2}
2) same system, only this time the mass is rotating, but its CM is initially offset by e.Same resonant frequency, wn. The whirling radius would be
r=e*(w/wn)^2/{1-(w/wn)^2}
which shows that whirling depends on an offset CM .
Without e , no whirling.
