Calculation of expanded tube and tubesheet joint according to ASME VIII div 1 Appendix A
Hi everybody!
I have a task to calculate expanded tube and tubesheet joint. In ASME VII div 1 App A there is calculation for maximal axial loading in which there is Po and Pt as interface pressures for which is stated that they can be obtained analytically or experimentally. I havent been able to found method for this calculation.
Also which criteria should I use when defining will there be one, two or more grooves and defining their dimensions? I found that main criteria is reduction of wall thickness which varies from material to material.
RE: Calculation of expanded tube and tubesheet joint according to ASME VIII div 1 Appendix A
Refer TEMA standard for grooves in the tubesheet for tube-tubesheet joints. In Section-5, depending on TEMA class (R, C & B), the grooving details are mentioned.
thank for information. It turned out that on my existing tubesheet expanded joints can't be applied due to tubesheet thickness. Once again thank you for the post.
