Designing Slab on Grades
Has anyone designed slabs for concrete thickness using the Portland Cement Association "Concrete Floors on Ground" method? The design charts only go up to an effect contact area of 100 sq. inches for tire loads. I was wondering what to do for larger equipement with much larger tires and lower pressures that result in a much larger effect contact area to design my concrete slab thickness. Thanks!
RE: Designing Slab on Grades
You might also want to get a copy of Army TM 5-809-12 (1987) "Concrete Floor Slabs on Grade Subjected to Heavy Loads." I just found this and haven't read it yet but it looks like good information.
--Winston S. Churchill
