Coach's elevator Catia V5 design
Hi people!
I'm Denis and I'm mechanical designer. Currently I'm working with Catia V5, developing an elevator with the aim to allow a minusvalid passenger to access a couch.
I'm usually using a generative sheetmetal module, and I quite an specific problem.
I would like to attack the problem this way: using booleans with this module. But Catia always make me use flat wall, which doesn't allow me to make the intersection boolean. Anyone knows how to make an extrusion as first step, or any other alternatives (normal bend or unfolded view doesn't suit me well).
Thanks in advance!
RE: Coach's elevator Catia V5 design
You should post this in the Catia forum and remove it from this forum.
Home > Forums > Engineering Computer Programs > General Engineering Programs > CATIA products Forum
