Pipe work estimate
Pipe work estimate
In terms of estimation or norms does anyone have any to had about pipework installation per linear metre plaese? It is just for installation and I can factor it up myself based on size/ material if you tell me the cost of iinstallation per meter. All material will be provided apart from consumables.
Many thanks. I did have a copy of norms from my old company but they got lost in cyber space.
RE: Pipe work estimate
http://books.google.com/books/about/Estimator_s_Pi...
prognosis: Lead or Lag
The materials prices vary too much with time and location to provide a meaningful cost/unit length, but the ratios above hold up pretty well over a wide range of prices and locations.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
