Octane Predictor
Octane Predictor
Hello Friends,
I would like to know if there is a mathematical correlation that can be used to predict reformate octane.
Kindly assist.
Kindly assist.
RE: Octane Predictor
There are also specific GC methods for octane determination from GC-PIONA. Some of these studies are published, the most famous being the method developed by Anderson et al. (you can find the references in Google) and tehre are also commercial GC equipment + software specifically designed for this purpose: GC-ON from Grace Davison and Carburane from IFP. These methods include specific correlations for each refinery stream (one correlation for FCC naphtha, other for reformate, and so). Indeed, you basically pay for the correlation developed from a third party, that include the analysis and correlation from a huge number of samples.
Alternatively, you could also developed your own correlation. This will be the most precise, but also the most time and resource consuming (you need support from a laboratory and time to develope your own naphtha samples database).
There are also methods that correalte octane from infrared (or near infrared) spectrometer. But I am not familiar with this specific technique
