fuselage parts
fuselage parts
I have a client who needs to perform bird strike testing. We did design work for them and now we are going to help them coordinate the bird strike test. Where do you buy fuselage parts for testing? I am in need of an A320 fuselage.
RE: fuselage parts
B.E.
RE: fuselage parts
i'd talk to airbus (to find out who's scrapping hulls), or google "used airbus parts"
Quando Omni Flunkus Moritati
RE: fuselage parts
Airbus should be able to advise where their bird-test facilities/cockpits/vendors are located.
Most transparancy/windshield manufacturers will have [or know where to go for] cockpits used in birdstrike tests. Find out wwhich company makes AirBuss A320 windshields.
NOTE. IF You are testing new windows/windshields and/or heaters these vendors may clam-up. IF installing new antennas or sensors [IR,UV, low-light, mircrowave, etc] on the cockpit or nose, then probably no problem with any of the transparency vendors cooperating.
rb1957 ... The Red Green Show ?? (wink)
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
RE: fuselage parts
@will, "if the women don't find you handsome, they should at least find you handy" ... i guess i'm 0-2 ?
RE: fuselage parts
My take on this...
"If You're not young/good looking, then at least try to be memorable"
Regards, Wil Taylor
Trust - But Verify!
RE: fuselage parts
must be a big antenna if you're worried about bird strike ?
RE: fuselage parts
There have been many cases where large birds penetrated the nose skins/substructure, or pressure bulkhead [after penetrating the radome and radar]... and the crew gets showered with "soft/foamy/feathery" debris.
I would imagine that hail and lightning strikes could also be a significant problem.
Regards, Wil Taylor
Trust - But Verify!
RE: fuselage parts
RE: fuselage parts
"On the human scale, the laws of Newtonian Physics are non-negotiable"
RE: fuselage parts
Reason for this is simple: acft fly at +body-angle of attack [nose up] at low altitudes, low airspeeds, so that the crown areas are "shaded" from bird strikes by the cockpit.
low altitudes = typical range for large birds.
Low air speeds = Typical operation environments at low altitude controlled airspace
Upper crown strikes could only occur at low altitudes, high airspeeds, when body angle of attack is "0" or below (-)0 [nose down].
An example of this might be the Navy P-8 [based on 737]: aircraft is flown at low level and relatively high airspeeds over the ocean during it's maritime surveillance mission.
Obviously lower body [belly] installations are more vulnerable that upper crown installations [except lightning and hail].
Has this aspect been discussed/evaluated with Your client?
Regards, Wil Taylor
Trust - But Verify!
RE: fuselage parts
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
RE: fuselage parts
i'd suggest designing a blow-out panel to prevent over-pressurisation of the radome if/when punctured by a bird
pls, let me know when you do the test ! or at least post video !!
RE: fuselage parts
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
RE: fuselage parts
We have an A320 fwd fuselage and I'm pretty sure that's where we got it.
RE: fuselage parts
RE: fuselage parts
Improper installation/mod, mechanical [hail, maintenance stand, etc], corrosion, fatigue or lightning damage would be 99.9999% reasons for crown antenna/radome damage/failures.
Bird strike? Doubtful: unless there is an aspect exposed in typical flight attitudes where birds could be realistically encountered, such as far forward, high crown. A tall blade could be an exception.
Ice-shedding, hail strikes, corona arcing, etc at cruise attitudes are more likely than bird strikes.
In this case keep the quail frozen
Regards, Wil Taylor
Trust - But Verify!
RE: fuselage parts
it might well not be likely, ice acreation and (possibly more imporant) ice shedding are other concerns, but you need to have an answer when they ask "and what happens if a bird strike happens ? how do you demonstrate compliance with 25.571e(1) ?" saying "it shouldn't happen" won't get you far.
i'm curious that this is for "an antenna under a "large" radome" ? is the concern that the bird will puncture the radome, and then impact the antenna with sufficent force to damage the fuselage under the antenna ? that sounds a little far fetched to me (possibly "extremely improbable") ... and Very hard to show on test; you need to get the bird to hit the antenna ? i know some bird strike tests show unexpected results ... once, firing a bird at a wing/fueslage fairing, the damned thing punctured the fairing (as expected) but then broke a small fuel pipe buried under some structure (for protection !) .... i reckon you can never predic where the bird will go, except that it'll go where you don't want to !
RE: fuselage parts
RE: fuselage parts
RE: fuselage parts
or look here ... http://answers.yahoo.com/question/index?qid=200901...
RE: fuselage parts
I tried boneyard2u - he doesn't tear down the airframes so he doesn't have it. Keep trying!
RE: fuselage parts
instead of testing, i'd've thought you'd get some milage from a NL FEA ?
RE: fuselage parts
NW used to tear down their old aircraft at Laurinburg, NC airport. Don't know if that operation still exists after the merger with Delta.
RE: fuselage parts
Does it have to be an A320?
B.E.
RE: fuselage parts
Todd Bradley
Site Operations Manager
Airport Road Building 600
Greenwood Ms.
38930
662-455-1826 Office
662-466-3427 Mobile
