Process Steam Condition Calculation
Dear all,
I wonder how to calculate the transfered steam condition at the end of the pipeline if we know the condition at the pipe inlet (250 oC, 16 barg, 20ton/hr) through the pipeline DN250, 6km with 4"calcium silicate insulated.
Is it possible to do it like this?
Firstly, calculate the pressure drop in the pipeline, then subtract it from the initial pressure so the pressure at the pipe end is known.
Secondly, calculate the heat loss through the pipe then subtract it from the initial energy to find the enthalpy at the pipe end.
Finally, the steam temperature is found from the end pressure and enthalpy.
Thank you in advance
TWC8
RE: Process Steam Condition Calculation
Your concept is correct, but you will have to do it iteratively because the pressure drop you calculate in step 1 depends on the exit temperature you determine in step 3.
Katmar Software - AioFlo Pipe Hydraulics
http://katmarsoftware.com
"An undefined problem has an infinite number of solutions"
Dear katmar,
Thank you very much.
