A newer version of this part is available since it was loaded in the session.
NX 7.5.5.4
Can someone explain to me why a file on my desktop, when I go to save it would be newer than than the one I currently have open in NX? It hasn't been changed while it has been open in NX but yet there is no possible way to save anything that I have done? This is becoming a big deal. Why doesn't NX lock files when they are open like every other software in the world (not sure if that is true but I have never run into this problem except for NX). I can't even 'save as', are you kidding me? Is there ANY way around this that will keep my parametric model in tact? And why does it happen? Also Export Part doesn't work.
Chase
Chase
RE: A newer version of this part is available since it was loaded in the session.
If this is the way that you're going to be working with NX then perhaps you need to invest in at least a minimum level of managed mode using the basic capabilities of Teamcenter. Please contact Siemens PLM or your local distributor to learn more about the options available to you and your organization.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I think NX simply compares the date & time of the loaded file to the file in the session and if the date/ time is newer of the loaded file, then "beep".
You should be able to do a "Save As" when this message appears, if not, you should check if your session crashed for some other reason.
The good thing about the "non-locked" files is that if your session crashes -whatever, the file on disk is not affected.
I have seen quite a few Word-Powerpoint-Excel-etc files over the years that got corrupted when the program crashed.
Tomas
BTW, if you really mean the files is on your Windows Desktop and you use roaming profiles, you are killing system performance. The file could be on some other computer's desktop as well as on a server that stores the roaming profiles. Storing files directly on the desktop is a very bad practice. Put them in a folder under My Documents and use a shortcut on your desktop if you MUST have it there for reference.
Ben Loosli
