Water main coupling fatigue
I had to "dabble" in some mechanical design and check flange sizes and rods/bolts for a 54" DIP main at a valve gate as part of a potable water system.
Do these components generally see a cyclical loading that would require fatigue to be checked?
In Russia building design you!
RE: Water main coupling fatigue
Independent events are seldomly independent.
