how to determine Xform in "ufs.Wave.CreateLinkedBody" & " ufs.So.CreateXformAssyC
hi -
maybe someone here can give me a little (big) help.
I have created a VB journal that can wavelink some selected bodies from any components ,to some other selected components.
every things work fine , but anyway not.
The positions of the linked bodies in the components-part´s is everybody in ABS zero . I need to have them positioned in their position as in the topassembly.
I think the Xform´s are the problem - but I´m not quite sure how to control these Xform´s.
lklo
CODE -->
For inx As Integer = 0 To TargetBody.length - 1
            selobj = TargetBody(inx)
            lw.WriteLine(selobj.NAME) ' output til test
            If ufs.Assem.IsOccurrence(selobj.tag) = True Then
                temp = ufs.Assem.AskPrototypeOfOcc(selobj.tag)
            End If
            ufs.Assem.SetWorkPart(temp) '   skifter workpart
            For inx2 As Integer = 0 To ToolBody.length - 1
                selobj = ToolBody(inx2)
                Dim MyComponent = selobj 'måske ok
                Dim CompPart As Part = MyComponent.Prototype
                Dim LinkedFeat As NXOpen.Tag = NXOpen.Tag.Null
                Dim ObjInPart As NXOpen.Tag = ufs.Assem.Askworkpart()
                Dim ufxform As NXOpen.Tag = NXOpen.Tag.Null'>>>>>>>>>>>>>>>>>>>> problem ???????
                Dim lkxform = CType(NXObjectManager.Get(ufxform), Xform)'>>>>>>> problem ???????
                For Each aBody As Body In compPart.Bodies
                    lw.WriteLine(ObjInPart & " --- ") ' output til test
                    ufs.So.CreateXformAssyCtxt(ObjInPart, MyComponent.Tag, NXOpen.Tag.Null, ufxform)
                    ufs.Wave.CreateLinkedBody(aBody.tag, lkxform, ObjInPart, True, LinkedFeat)
                    ufs.Obj.SetName(LinkedFeat, MyComponent.Name)
                Next
            Next
        Next
