Concrete slab around an interior pool
An existing interior pool, several decades old. The owner wants to replace the slab around the pool because it has deteriorated a little bit and the architect wants to ground the reinforcement for the slab. Can this slab be a regular 5" slab on grade with rebar or is there something special about the concrete mix/rebar/vapor retarder etc that we need to address.
Thanks.
Thanks.
RE: Concrete slab around an interior pool
Don't forget the isolation joint between the slab and the pool structure!
In Russia building design you!
