Cutting off Dimensions
I'm trying to dimension to something fairly far away from the part itself and I don't want the dimension line to go off the drawing page.
Is there a way to cut off a dimension? To only have one leader the dimension and then the line ends at some point?
RE: Cutting off Dimensions
http://files.engineering.com/getfile.aspx?folder=d...
It's not exactly what I wanted, but it's close enough.
-handleman, CSWP (The new, easy test)
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
