API seal plan to vertical pumps
Hello people,
I need some help to specify a plan flush, I am going to pump crude oil 19,3º and 77,14 Cst @ 50ºC ,
I think anything about 13/52 and 65 to dual seal.
anybody has a any suggestion ?
thanks
thanks
RE: API seal plan to vertical pumps
If not, single seal with a plan 14 should do fine (with a 65 if you want.)
Then buy half a dozen spare seals with the money you save over dual seal + 52.
My preference would be dual pressurised seals and although initial cost is high reliability is also high. If cost is an issue then consider single with a quench. If steam is not available i wouldn't use single seals.
Johnny Pellin
