How to sum or calculate voltage or current harmonics component that are in parallel ?
Recently I measured voltage and current harmonics in coal mining industry. But they only have Power Quality Meter with limited current clamps (not big enough for the PCC(point of common coupling)). So I decided to calculate it load by load. Is it okay?
If it is, then How to sum or calculate voltage or current harmonics component that are in parallel ?
I want to sum some lines (every lines contains different voltage and current harmonic components).
Is it just sum every n-th component by the same component ? Or how?
Let me give a case:
I have three lines: line a and line b, and line c
in line a-> I have inverter, which has biggest distortion at 5th harmonic and also another harmonic components
in line b-> I have a device that has biggest harmonic at the 3rd
in line c-> I have linear load, so there is no Voltage or Current harmonics
So how can I calculate the sum of these three lines,(how to sum both current and voltage harmonic)
And another question if possible. Can we convert three different single-phase voltage components into three-phase voltage components?
Sorry if it is too wordy. Thanks
Let me give a case:
RE: How to sum or calculate voltage or current harmonics component that are in parallel ?
The voltage harmonic depends on the source impedance. If you are measuring each line harmonic voltage at the same point, then the harmonic voltages will be equal.
but, I have one more problems
what will happen to current harmonics if it across the impedance above it , or wye-delta transformer above it,what will happen to the summed current harmonics.
will it decreasing? how can we calculate it?
Phase shifting one-half of the load through a delta-wye transformer can greatly reduce the 5th and 7th harmonic currents in the sum of non-shifted and shifted currents. This is if the non-linear loads on both shifted and non-shifted are the same. This is the basis of Harmonic Mitigating Transformers (HMT).
You can calculate it by adding the phase shift to the sinusoidal functions. Keep in mind that the phase shift of the nth harmonic is n times the fundamental phase shift. This is why balanced 3rd harmonics are zero-sequence. Phase B is shifted 3 x 120° = 360° from Phase A. A 360° phase shift puts Phase A in phase with Phase B.
So when it's 7th and delta-wye, it need to be shifted 7x120
when it's 7th and wye-delta (harmonic current move from wye to delta) it need to be shifted -7x120 isn't it?
This gives rise to a side discussion at:
thread238-341550: Even Order Harmonics as early detection of failure.
Bill
"Why not the best?"
Jimmy Carter
Some equipment indicate even harmonics also when there are none. I had a problem understanding how there could be a rather high even harmonics contents where there couldn't be any. It turned out that the Dranetz 4300 I was using, and still use now and then, doesn't have an anti alias filter that can handle components at around 8 kHz. The low sampling frequency made these components appear as odd AND even harmonics. I have heard that the problem exists also in later versions of Dranetz-BMI equipment.
It is quite easy to test if your power quality analyzer has that problem. Just connect a function generator and test with a few frequencies above the analyzer's specified frequency range. If it shows even harmonics, then you have that problem.
Gunnar Englund
www.gke.org
Bill
"Why not the best?"
Jimmy Carter
Thanks a lot for all your response jghrist.
Really, you are a big help
