3~motor rated for 500V/50Hz/0,75kW and 575V/60Hz/0,86kW
What will be the difference in current flow, speed and power if I connect 3~motor to mains 400V/50V or to mains 480V/60Hz. In which case will be the current and power bigger? Will be the speed different?
3~Motor data are as follows:
50Hz/ 500V/ 0,75kW/ 1,92A/ 2855/min
60Hz/ 575V/ 0,86kW/ 1,96A/ 3455/min
RE: 3~motor rated for 500V/50Hz/0,75kW and 575V/60Hz/0,86kW
If I'm not understanding your question, please clarify and I'll try again.
