Returns the formula of derivative of f(t) ?
Dear all,
Does someone know how to return the FORMULA of the derivative of f(t)? If I do 'd/dt (f(t))', I only got the results of the derivative.
I hope someone can help me. Thanks anyways.
RE: Returns the formula of derivative of f(t) ?
First, if you want the formula, you are looking for a Symbolic solution, which means that you need to use the Symbolic evaluation selection from the menu or [CRTL}-"."  You should get a right-pointing arrow.  This requires that your variable be undefined, otherwise the symbolic evaluation will substitute where possible.
TTFN
