Difference between Mazatrol and G-codes
Hello
Thank you for entering in my post
I am totally new about Mazak Milling Machines
On the the top of the control pannel is written Mazatrol 640M, so i thought the machine works with this software with G-codes instead making some search i realised that there is a difference between Mazatrol and G-codes so probably thi Mazak machine doesn't use a Mazatrol software as it is witten on the top of the control pannel but a Fanuc software, Is it right?
any information according this matter will be very appreciated
Thank you in advance for your help
RE: Difference between Mazatrol and G-codes
